- Vie Ene 30, 2009 21:07
#288624
y po si no queda claro, aqui desde los dos lados:
![Imagen](http://www.motorcycle-usa.com/photogallerys/06-precision-concepts-3.jpg)
esta configuracion es cara de cojones:
Parts and Labor
Suspension: $981.56
- Fork Revalve
- Shock Revalve
- Service Linkage
- Service Swingarm
- Service Steering Stem
- Service Steering Stabilizer
- Add CR500 Body to Shock
Carbon-Fiber Fork Guards: $69.99
HRC Power-up Kit: $1009.99
- High-Compression, Cast Aluminum Piston
- High-Lift Cams
- Reinforced Cam Chain, Cam Guide and Clutch Springs
Oil and Oil Filter: $31.96
Radiator Fluid: $11.98
Ventilated Side Panel: $59.99
Block Off Kit: $26.99
Choke Plate: $29.99
Carburetor Jets: $15.96
Intake Manifold: $12.99
Pro Circuit T-4 Exhaust: $674.99
Exhaust O-Rings: $6.99
Rubber Pipe Mount: $39.95
Johnny Campbell Signature Triple Clamp: $209.99
Scott's Steering Stabilizer w/Mounts: $659.99
Renthal Bars: $89.99
Cable Guide: $15.99
Works Connection Reservoir Cap: $24.95
Works Connection Clutch Perch: $164.99
Front Wave Rotor: $284.99
This was the scrap bin. We haven’t seen these parts since leaving the bike in Murrieta.
All of these parts and more were replaced with aftermarket units that have met the rigorous PC testing standards.
Ceramic Brake Pads: $119.97
IMS Footpegs: $99.99
Precision Concepts Footpeg Mods: $149.99
IMS 3.4 gal. Fuel Tank: $225.99
90-degree Tank Fitting: $19.99
Petcock: $7.99
Tank Foam: $59.99
Renthal Chain and Sprockets: $249.99
Radiator Cap (1.
: $34.99
Dry Brake Receiver: $249.99
Front Wheel Spacers: $49.99
Rear Wheel Spacers: $26.99
Dunlop 742 Front Tire: $59.99
Dunlop 739 Rear Tire: $74.99
Ultra Heavy Duty Rear Tube: $24.99
Rear Rim Lock: $28.99
10mm Bolt Kit: $39.99
Tank Graphics: $39.99
Heat Shield: $97.99
Misc. Pieces: $49.95
Total Parts: $6136.96
Labor: $2850.00
Parts and Labor
Suspension: $981.56
- Fork Revalve
- Shock Revalve
- Service Linkage
- Service Swingarm
- High-Lift Cams
Choke Plate: $29.99
Cable Guide: $15.99
Petcock: $7.99
Tank Foam: $59.99
Radiator Cap (1.
![Cool 8)](./images/smilies/icon_cool.gif)
Heat Shield: $97.99
Labor: $2850.00
